I don't know if people know it in Australia but up north in Europe we can run something called Liquefied Petroleum Gas to run our cars instead of (most of the time next to) petrol. Most people studying chemistry or physics know gasses carry less energy than liquids, but instead of paying
Opinion on LPG
Yeah in AUS, we have LPG, have had it for years, back in the early 2000's there was an incentive given to people who would take their car in to get a gas exchanging unit installed on their vehicle, my hilux had a gas tank and kit on it when i first got it but i chose to remove it as it was big and bulky and did not increase performance on my vehicle as well, as for the tank it was out of date so it needed to be inspected and ran through a heap of tests that way it was safe for use, but as i said, i didnt find any use for it.
Lots of cars here have Duel Fuel, which is a car having both tanks, and or exchanging unit.
A fair few aussie cars were manufactured with just LPG systems, the Ford Falcon being one, the BA falcon right up to the FG model had a dedicated LPG system, and an engine that had small differences for the system and the main noticeable difference is the GREEN rocker cover on the Barra 6cyl producing 156kw, and then in the later FG-FGx models had the EcoLPi barra running 198Kw
Ford Australia was the main manufacture in Australia to take advantage of LPG systems, and the cost of LPG at the Bowser/pump is still much cheaper then Petrol and diesel, even E10Last edited by xLOCOx; 14-09-2018, 10:25 AM.
Originally posted by Vinhes View Postyeah thx, idk how that happened xD
ANYWAYS my experience of LPG is reduced engine power overall, lower throttle response and really bad MPG. My dad had LPG fitted to a 3.6 litre XJS (Incentives to do this in the late 90's early 2000's), dual fuel so it could still run normal petrol. it managed 28-30mpg on the petrol but managed a massive 11mpg using LPG** Because it was so much cheaper to buy, it was cheaper per mile than petrol. The only other upside is cleaner emissions.
** We drove until the car died, then restarted it and drove another 2 miles on LPG before it died again and switched back to petrol. We managed 185miles to 80 litres of LPG.
It's maybe more effective on much smaller engines? You should definitely let us know how you get on with it for cost and mpg
in the future I think there's more development coming for LNG rather than LPG. It's got a higher energy density so it's comparable to petrol or diesel. I think Volvo were (or still are) developing LNG for the Volvo FH series - with the same power outputs.I stripped my car out so much it now has 49/49 weight distribution.
Originally posted by MartinObviously View Post
Probabaly used a currency symbol the forum doesn't like!
Yeah probably because I used the euro sign xD. Anyways got my car back friday, strangely noticed an increase in power and a more direct throttle response. Completely the opposite from other peoples' experiences. So far I love it. Still finding out the MPG though, my car is a 1.3l and was designed to run LPG seeing as there also was an LPG option for the Mazda 2. Only the LPG was 75hp and mine is 86hp, which is quite unique among the Mazda 2's from my generation.
Originally posted by sebe20 View Post
That's an interesting experience, a friend of mine had a V8 BMW with LPG. It was the only reason he bought because petrol for that thing was expensive, he wouldn't be able to afford it- The only problem was, in the end, the servicing of the LPG System was costing him so much he had to get rid of it. Other than that, he only felt the LPG System aktivating past 60 km/h and only when the engine has reached operating temps. Performance wise there wasn't much difference he told me. So maybe you could do some tests like 50- 150km/h with some gps at will take the exact times? Did that with my Fiat to see improvement before /after chiptune and with different fuels. Would be interesting some power gains / decreases
LPG is great. Yes MPG is worse, but its so much cheaper then petrol or diesel. If you cover a lot of distance during the year it save you a lot of money.
Dutch government is on it like a mofo though, LPG systems can only be installed by specialists now, cost about 1200 euro's. On top of that, road tax for an LPG car is more expensive.
There's this Dutch online calculator that calculates the crossover point when LPG is cheaper then diesel or petrol. I do about 22.000 kilometers a year in my car, and LPG is cheaper starting at 4129 kilometers. But it'd take a year before I break even after having LPG installed in the car.
Originally posted by TheCaptain View PostLPG is great. Yes MPG is worse, but its so much cheaper then petrol or diesel. If you cover a lot of distance during the year it save you a lot of money.
LPG is brilliant.
In Australia, it's typically half the per litre price of petrol or better. You do get slightly worse fuel economy with LPG because petrol weighs about 730g/L vs LPG at 515g/L, but at least in Australia, the operating cost per km for LPG shakes out to 50% less than petrol, even with the poorer km/L figured in.
There's also the benefit of LPG's octane rating, 100-112 in Australian mixes of propane & butane (varies by time of year), so it's better for high compression or turbo/supercharged applications. The higher octane number indicates a longer hydrocarbon chain, which is harder to ignite and thus less prone to preignition/pinging/detonation. Normally aspirated engines can benefit from a bit more timing advance on LPG. This is improved even more in direct liquid-phase LPG injection as the release of pressure of liquid phase LPG results in cooling of the intake charge and cylinder. Means you can get a denser air/fuel charge into the cylinder = more power, which is part of the effect you get from nitrous oxide injection. It's an excellent racing fuel- check out Scotty from Carnage's Turbo Taxi on YouTube, which is a retired Falcon taxi running a 4.0 litre 6cyl Barra engine. Turns 11 second 1/4 miles reliably. https://www.whichcar.com.au/tv/carna...axi-part-three
Top that off with LPG being a 'dry' fuel that can't wash oil off cylinder walls and also combusts fully, with no abrasive soot. Engine oil on LPG engines doesn't come out black & gritty- it's a clear honey colour, even after about 5000km. Nearly all Aussie taxis run LPG for both the running cost reduciton and engine life extension, not unusual to see 500,000km on LPG taxi engines.
I put an LPG system on my ancient 1987 Toyota Hilux to both cut the running costs and extend the life of the engine. Cars of this vintage are not E10 compatible. Ethanol will dissolve incompatible plastics and rubber parts. A tank of E10 will trash the petrol fuel system in a mid-80s spec Aussie car right away. The Aus govt is trying to force ethanol fuel on the motoring public by mandating sale of E10, so plain petrol is getting harder to find. LPG is a great solution for these cars
Ethanol is fine for engines and fuel systems that are built for it- it can be a great racing fuel as it will support higher compression, as Marty & Moog have shown numerous times, and the more the better in such applications, which is why they love E85. However, it's terrible for older cars which have non-ethanol resistant fuel system parts. E10 is a bad bet for fuel economy as ethanol only has about 50% of the energy content of petrol- so E10 only yields 95% of the thermal output of plain petrol. Means you get an instant 5% fuel economy reduction penalty.
Would be OK for compatible vehicles if it were priced (at least) 5% less, but E10 is typically only a couple cents per litre cheaper than plain petrol in Australia. In dual-fuel cars, E10 is even worse, even in compatible cars. Ethanol is hygroscopic- it absorbs water from the air. If you have a dual fuel LPG/petrol car and mainly burn LPG but keep some E10 in the petrol tank, your tank of E10 has plenty of time to absorb a bunch of water- which will make a right mess of things.
It's expensive to put an LPG system on a car, about $2000-3000 in Aus. However, if you have a car that you intend to drive until it drops, there's nothing better. You will save the installation cost in reduced fuel expenses in a couple of years. You'll pretty easily double or triple the life of the engine. If you're an eco-nerd, you'll appreciate the instant 15% reduction of CO2 emissions per km on LPG. I'm just in it for the cheap motoring.
- 1 like
