GFB SuperCheapAuto Haltech Ryobi CastrolEdge CenturyBatteries WD40 Michelin NGK KYB
Painting your Car
  • Painting your Car
    Im curious , i need to do a full repaint of my car but don't have a air compressor and gear. I was in bunnings and saw they had a electric paint sprayer for only $50. My friend said it would work for painting my car too. So what im asking is for advice. Do you think it could do a better job then spray painting my car using cans and has anyone had any experience using the electric sprayer or should i wait a few months until i can save for a air compressor.
    Nope, those sprayers you've found are 1. likely for water based paints, like you'd use on houses. and 2., spraying with extremely BIG droplets.
    It might work to do your car, IF you're doing a single stage acrylic and spend a week with some 800 grit cutting it back; but it's just not worth the effort.
    Save up for this:
    Origin Air 3.0HP V-Twin 220LPM Compressor
    https://www.tradetools.com/product-r...lpm-compressor
    You'll never regret having a compressor. This is the most powerful compressor you'll find, without going belt driven (more expensive) and without needing a 15A power socket in your house.
    Cheap SCA sprayguns after that will do fine.
    You want to AVOID HVLP spray guns, because even though they're low pressure (LP) a household compressor has a hard time keeping up with the HV (High Velocity) of air needed. You're better with a 'conventional' gun (Medium on both).
    However, if you're not spraying metallic, then even if you get a HVLP gun, you can pause between panels for a minute to let the compressor catch up.
      Thanks for the tip , i ended up splurging and i bought a 240LPM Compressor from supercheap auto and repainted my car orange and black. I'll upload some pics once its dryed and i remove the paper.
        Wait What? Did you go belt driven? How did you get above 220LPM? I can't find a model in their store.
