Automatic transmission converted to manual
  • Automatic transmission converted to manual
    Not sure if this is actually possible but I’ve been curious about it. Would it be possible to just take an automatic transmission. Change the bellhousing, flywheel, driveshaft, and add a clutch… and then just have a manual transmission but with the auto gear ratios? Would this work or is this just dumb?
    No. Internal workings are totally different.
    You can manualise most automatic transmissions though - no clutch, but it would be as close as you're going to get without actually fitting a manual transmission.
      Auto to manual is a big job, and thats just the part swapping, electronics will be the real headache
