What is the purpose of a car's oil catch can? [A newbie guide]
  • What is the purpose of a car's oil catch can? [A newbie guide]
    The oil catch can, or oil catch tank, is a component linked to a vehicle's crankcase ventilation system that filters air and impurities out of the oil. Oil catch can is a standard component on a select few autos.
    Physically, it has a cylindrical shape with a pair of appendages, mainly fasteners and tube nozzles. This device is usually constructed of plastic.
    Advantages and disadvantages of oil catch cans
    The prevention of greasy fumes created by blow-by from collecting in your car's cylinders is a significant benefit of installing the oil catch tank. This translates to improved working conditions, which leads to increased efficiency. In addition, the gunk I stated can result in shaky starting, ignition failure, or power loss. Those can also be avoided.
    If your turbo utilizes exhaust gas recirculation, this gadget is also quite useful. This is because the oil catch tank may filter out any muck that collects on the turbo's cold side and intercooler’s interior. Furthermore, sludge that causes intake valves to stick. When this happens, performance suffers, especially for high-performance and high-boost turbocharged vehicles.
    In terms of drawbacks, these cans can be costly in the Philippine market. There are standard oil catch cans, but having a model-specific one is preferable. For most amateur mechanics, the installation of these cans is also difficult, but this may be readily remedied by employing a specialist.
    Also, if you're especially meticulous about engine maintenance, you may not need these cans at all. Finally, during oil changes, oil catch tanks must be drained. To put it bluntly, this means additional hassle during your routine maintenance.
    An oil catch can be made yourself. The process isn't complicated at all.
