hah wtf XD
Question for the bikers
I've found that smaller displacement bikes are often more fun than larger ones. I've had lots of fun on 125s and the like.
Land speed records for 125s are like 150mph; so fast can happen on a little bike.
BUT if your out for speed there are a lot of things you can do to make that 125 faster.
If you're looking at a 4 stroke.
1) bigger carb. Definitely the best bang for your buck here. Not so much bigger but better designed. Get a flat slide vs a round slide like most small disp bikes use.
2) ignition advancement. Lots of newer bikes use CDI ignition There are dozens of aftermarket CDI programs that are plug and play.
3) cam. Depending on your bike there might be an aftermarket cam available.
4) exhaust. Don't go hog wild on this one. Exhaust doesn't do as much as most will lead you to believe, but it most defentely helps if you've done the other 1,2,3 things on this list.
If you're looking at getting a 2 stroke.
1) carb. Same as a 4 stroke
2) port. Opening your intaking ports earlier will drastically change your power band. This is gonna be different depending on the engine you are dealing with, and the exhaust plays a major role in this.
3) exhaust. Major game changer in the 2 stroke world. This will make all the difference in the world, from power band to fuel economy.
Most of this stuff can be done with a couple of bucks and will make your motoring experience better.
- 2 likes
Originally posted by Qingdao View PostI've found that smaller displacement bikes are often more fun than larger ones. I've had lots of fun on 125s and the like.
Most of this stuff can be done with a couple of bucks and will make your motoring experience better.They say a dog is a man's best friend, but I don't even have enemies that would look me dead in the eye while sh*tting on my floor...
