If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
In this video some friends and I start getting our hands dirty learning about the RX-8 and learning the specific history of this car. https://www.eazyoncars....
Today we pull the Renesis engine and open it up to find a spicy dorito! https://www.eazyoncars.com https://www.instagram.com/eazy_on_cars/ https://www.facebo...
In this video I harvest the engine for the RX-8 swap. https://www.eazyoncars.com https://www.instagram.com/eazy_on_cars/ https://www.facebook.com/eazyoncars/...
Make sure you sort the electrics to. Being a flood car it's gonna have lots of moisture in all kinds of electrical bits. It might not give problems now, but moisture inside a plug can take very long to dry and cause problems months after you think the car has dried out
Also, I like rotary's and I like RX8's, so bit of a shame to shove a V8 in it to be honest with you
I'll be redoing most of the wiring, going to take each component one by one, but its been promising thus far.
I hear you on the Rotary front for sure. Honestly this thing would have been crushed if I had not scooped it up and there is no way I can justify a rotary build. The amount of work that needs done to the car and amount of budget I have to throw at my second project car is very low. Cheers to keeping the chassis alive mate!
That big? It is a little.
When people put a modern LS series in them though; that's ideal.
-Uses Less fuel.
-Isn't significantly heavier
-Still Revvs freely.
-Adds torque that rotarys lack.
There's really no downsides.
Rotarys are cool IF and only IF you intend to keep them at that required 75% RPM range to be efficient.
The engine is damn cool for drag, or even track or touge work.
But it's just a really stupid idea for a street car, the rev range required is far greater than the efficiency band.
I'm hoping my next car is an LS swapped RX8.
There's one for sale in my state; but it's about 13 hours drive away, so I need to put a day into a drive and go have a look at it.
-Uses Less fuel.
Aksheually those are only problems with Mazda style rotaries i.e no recovery and oil cooled rotors and a non optimal design - probably for cost reasons.
I'd use a rotary for street, they run so smoth
I've got a friend who swapped his RX7 engine for a K20 turbo, Jesus it was fast.
V8 one will be awesome, it's an available engine too
-Uses Less fuel.
There some downsides... the engine is bigger and goes over the front wheels, instead of behind them, so you are transforming a central engine car into a front engine car.
