forza 4 drift tunes
  • forza 4 drift tunes
    these tunes are quite good and if you message the car you want a tune for and the drive you want it i will make it and post it on the forum in this thread, my gamertag is (leewtp96) add me if you want to buy or swap designs unlocked on forza.
    heres a tune to start u off
    mazda rx7 gsl-se rwd
    conversion
    spirit r engine
    single turbo
    engine mods
    race everything
    stock flywheel
    plattform and handling
    race everything
    stock weight
    drivetrain
    race everything
    tyres and rims
    race everything
    any rims and sizes
    aero
    any
    tune
    tyres
    front
    30.0
    rear
    35.0
    gearing
    final drive
    2.20
    1st
    3.95
    2nd
    2.96
    3rd
    2.23
    4th
    1.81
    5th
    1.50
    6th
    1.28
    aligament
    camber
    -5.0
    -2.8
    toe
    0.0
    0.0
    caster
    5.0
    antirole bars
    front
    28.20
    rear
    28,20
    springs
    front 582.0
    rear 533.0
    front 5.0
    rear 5.8
    dampning
    rebound
    8.0
    7,8
    bump
    6.1
    6.0
    aero
    stock
    braking
    stock
    diff
    front
    66
    rear
    64
      add your tunes aswell if you want to
        I can't give away my Top Secret S15 tune, because it's top secret
        But I can tell you a good base starting point.
        I use this formula on basically every drift car I set up.
        Tires: 35 psi both (Not that important) Generally I use Sport tires unless the car is under powered which I will use Street tires (Not stock)
        Gear ratios: You have to set to your liking. I like mine really close so that you have a lot of adjust-ability when driving and the ability to drift in ALL 6 gears. I like to set it up so 1st gear is an 80 mph gear and 6th is about a 175 mph gear, all other gears set equal distance apart from each other.
        Alignment: I start the same way on every car. +3.5 camber front and rear, front toe +2.5, rear toe +1.0, caster 4.2.
        Now the math comes in. Grab a calculator.
        Sway bars are set to a 40 point variable. Find the front weight percentage of the car and multiply 40 by the front weight percentage. (Say your front weight is 55%, you multiply 40 by 55%, you would get a sway bar stiffness of 22. Same for the rear, just instead of using 55%, you would use the REAR weight which in this case would be 45%, do the same thing and you would get a sway bar stiffness of 18.)
        Same story for Spring rates. Grab your calculator! Here's what I do. Take the weight ov the car and multiply by the front weight percentage again. Say the car weighs 2400 pounds with a front weight of 55%. You multiply over all weight by front weight percent, which in this case would give you 1320, now take that number and cut it in half. You get 660, there is your front spring rate! For the rear, same thing. 2400 * REAR weight percentage (45%) and divide that number by 2. You would get 540.
        Curb weight * Front weight percentage = # / 2 = spring rate
        Curb weight * Rear weight percentage = # / 2 = spring rate
        Dampening I set to the first two numbers of the spring rate as my bump stiffness. (If it's 660, bump stiffness would be 6.6) As for rebound, it's your bump stiffness +2. (If your bump is 6.6, your rebound would be 8.6)
        I don't do much with brakes, and my diff is always 100% lock accel and decel.
        That's pretty much it... To much time and effort into figuring out a good base to set up cars in a video game, I know.
        Try it! Your cars will be VERY snappy and a little hard to get use to at first, but it's hard to spin them out because they get a ton of angle, and a good driving tip is if you aren't sideways enough to keep it going, use more throttle or shift up! If you are starting to spin out, shift down and let off and/or grab some E brake!
        I'm currently ranked in the low 600's in RWD drift so I like to think I kind of know what I'm doing... Give it a try! Hahaha
        Damn you kaka krabby patty!
        ._/_____________\_.
        (OO/ - . . . . - \OO)
          cool cheers i will try it.
            Great rx7 tune!
              Originally posted by Nates-vtr View Post
              Great rx7 tune!
              cheers are there any more tunes you want i have loads for fwd rwd and awd and will make them if i dont allready have them.
                Hmm maybe a drift one for the ae86?
                  ok will post one up tommorow do you want rwd or awd?
                    Rwd plz
                      i have a pretty good drift tune on my s13, willl lookk at it later
                      cheers
                      SIGPIC CREATED BY THE LEGENDARY TOMMMMMMMYYYYY!!!!!!!
                        stock weight
                        tyres and rims
                        race everything
                        gearing
                        final drive
                        2.20
                        Race tyres are awful for skids. Also it's a crime to swap the FB engine and lose that BRAAAP.
                        As for the final drive why did you bother putting the big engine with race parts in just to put it down to 2.20 final drive? That's akin to building a 900hp motor then restricting it to 250hp. May as well just go with a less powerful motor and not pussy out on your final drive.
                          dose it really matter at least it drifts and it drifts good if you dont like it dont use it.
                            toyota ae86 rwd drift tune
                            conversion
                            mr2 95 engine
                            engine
                            all race
                            handling
                            all race
                            drivetrain
                            all race
                            tyres
                            street compound
                            race tyre widths
                            any rims and sizes.
                            tune
                            tyres
                            30.0
                            30.0
                            gearing
                            3.30
                            2.80
                            1.92
                            1.44
                            1.17
                            1.06
                            0.89
                            alingment
                            -4.5
                            -3.2
                            0.0
                            0.0
                            5.0
                            roll bars
                            27.69
                            22.07
                            springs
                            458.8
                            451.0
                            5.3
                            5.3
                            dampning
                            7.7
                            7.5
                            5.9
                            5.8
                            diff
                            75%
                            68%
                              its a little bit twitchy
