so its still just a neon right? isnt that what most people say about them?
2.4l 4cyl turbo
full street weight all the time, i dont remove seats or my system or any other garbage when i run my car at the drag strip, i run what i brung always. maybe a set of drag radials now and then but thats the most i'll go.
basic bolt-ons:
60mm throttle body
full 3" exhaust (custom made) w/ 3" high flow catalytic converter
full 3" cold air intake (yes with a cone filter)
8mm granatelli spark plug wires (lowest ohm loss from the coil to plugs as far as i've seen)
huge front mount intercooler
AEM tru boost gauge style electronic boost controller
AEM UEGO air/fuel gauge
mopar stage 1 pcm
with just those mods my car made 264 horse power 341tq on a dyno jet and went [email protected] in the 1/4
newly installed mods:
888cc fuel injectors (58lbs)
walboro 255lph fuel pump
borg warner S200sx-RS-56 turbo
AGP t3/t4 turbo manifold
AGP-38mm external wastegate with a 9psi spring
AGP intercooler pipes
HKS SSQV-v4 blow off
clutchmasters stage 4-6puck clutch/flywheel
SCT-pcm reflash
ngk irridium plugs gaped at .032
other mods:
Solid Motor+tranny mounts for that extra traction(less wheel hop)
lowered by 1.6inch front 1.8 rear (so it sits flat and not having its rear in the air)
motegi mr7 white rims painted black 17"
mopar 3d tail lights slightly modified so they are all black instead of having this stupid silver ring around the break light portion.
20% rear tint/50% front tint on the windows
kenwood 1000watt amp
2farrad capacitor
audio bahn single 12" 2400watt sub
full pioneer speakers 6.5" fronts, 6x9 rears, 4.5" in the dash
borrowed a jvc head unit, my kenwood sadly broke after a strong 8 year run
mods still to come:
2.0L CAMs out of anything with a 420A engine, more then likely a stock 95'-98 neon or eclipse non turbo
remove my balance shaft assembly
new e-bay 3" exhaust (yes ebay who can argue with 238usd shipped for a full turbo back exhaust? specially when people said they saw gains and they sound decent?)
currently i am still only running 12psi even though on the stock turbo i was at 18.7psi, i dont have the new clutch in yet, and its still running VERY rich (14.2-15.3 at idle) so to avoid killing it before i have a go at it i'm no boosting much, it pulls harder on 12psi then my stock turbo pulled at18 though so that a bonus.
on this set-up i should be able to run 20psi and, though its an estimate, be putting around 420-430 horse power to the ground, after 22psi the reflash pulls timing expecting race gas and here in the states race gas runs around 12-15usd a gallon depending on what you get. so thats probably not gonna happen.
currently about 3 years ago someone backed into my rear driver side door and put a nice dent in it, insurance wouldnt cover it so i gave up completely on trying to keep the car looking like new, black is the worst color and never again will i own a black car, so it looks like crap but its fast, i just cant bring my go to a show fight
so for those who dont know the bottom end on these cars were built to survive a nuclear blast and keep going, however the top end is the same you'd find in your daily driven car, however they are exceptionally strong and regularly run 25psi on a completely stock engine's internals. so with a new set of pistons and rods this car can easily handle 25-30psi and not break a sweat, as long as you other mods support it.
eventually i will post pics but as i said it looks like garbage due to lack of exterior maintenance due to me giving up after the door incident, but pics will come non the less.
**EDIT** because i always forget something ive done to my car lol
**EDIT2** today 4/20/12 i bought some dodge caliber srt4 3bar maps, so i have a 3bar map and tip sensor, yes they are exactly the same sensor just when bought as a neon srt sensor they go for 80$USD and the calibers came with them factory so they cost 25$usd its just a matter of getting a file and shaving off a little bit here and there to get them to work.
so now it runs alot better, i can now go WoT and its holding right at 11.0 and thats at 11psi so i will need to reflash my pcm to make up for when i hit 20psi but until then its fine and runs much better
2.4l 4cyl turbo
basic bolt-ons:
60mm throttle body
mopar stage 1 pcm
SCT-pcm reflash
other mods:
2farrad capacitor
mods still to come:
