transmission fluid instead of power steering fluid?
  • transmission fluid instead of power steering fluid?
    steering is making nasty noises which im quite sure if the power steering complaining about being thirsty, ive heard you can just use transmission fluid to fill it up, is this true or will it do damage?
    car is 04 fairmont ghia
    I'll be quite confident that it'll flog the p*ss out of a lot of cars. This thought gives me happy feelings in my pants.
    ╔═════════════════ ೋღ☃ღೋ ════════════════╗
    ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ Repost this if ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~
    ~ ~ ~ ~ ~ ~ ~ you are a beautiful strong N/A engine ~ ~ ~ ~ ~ ~
    ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ who don't need no tarbo ~ ~ ~ ~ ~ ~ ~ ~ ~
    ╚═════════════════ ೋღ☃ღೋ ════════════════╝
    It depends what the seals are made of in the rack, but i don't see why you wouldn't just use ps fluid.
      Well I'm fairly certain PS fluid in a transmission is a bad idea.....so I think this logic works the other way too.....not certain though.
        I'm running ATF in lieu of power steering fluid, but only because I had some lying around that saved me a trip to buy some PS fluid and it's been well documented to work fine on my particular vehicle.
          generally it's okay, grab the manual that came with the car and check what the actual oil standard is, it'll say dexron 3 or something weird like that
          just match it up with whatever ATF/PS fluid you have access to.
          Love MCM? Want to help support the show? Check out the MCM Shop and get some maaaad DVD's, stickers, shirts or Magazine...
            just considering using trans fluid since we dont have ps fluid lying around, but we do have trans fluid (fairmonts are autos), so going by adowbs and this mechanic i heard it from, should be sweet?
              cheers mate
                Just ran out to check, indeed Dexron III ATF fluid is what I'm using in mine right now.
                  This//
                  I use ATF in my statesman for the power steering...works fine and is listed in the manual as well
                  Sent using eBay turbo at 40psi
                  scratching ur face with the middle finger when a cop is looking at u
